I was letting my eg warm up the other day while putting on some new wheels and tires. Ran 15 to 20 minutes no problem. All of a sudden she started to idle lower, spit, sputter, then died. Tried to start the car back and she would try to start but backfire and not run more than a couple seconds. Changed the fuel filter, no difference. It is a cx with a d16z6 swap. I dont have another person to help check ignition. Any ideas? My only guesses are ignition related or timing belt jumped a tooth. It has always been hard to start when cold. But I just thought that was the iac valve and was too lazy to take it out and clean it.
I appreciate the help man, but I checked all four plugs in their individual plug wires. I seriously doubt all the plugs are bad. And, like I said, I verified the timing after you posted the correct timing mark. Plus coil ohms out bad at the correct temperature. It's raining and 35 degrees here and didn't get photos of the timing. I'll post once I replace the coil.
Well the coil fixed car yesterday. I rode the car around, started up fine, etc. This morning I went out to start the car and it's doing the same thing again. Backfiring and no start.
Sorry for not responding for a few days. Got the spark issue fixed, then found out I had water in the gas. Drained the tank and put fresh gas in, runs like a top.
