Ctr cluster into Crx 1990 si
I'm have real trouble been following with this cluster swap so I re pin the connectors I got them from 97 civic and the vss connector too so at first I connected it everything and the vss plug I plugged it in the trans and the other end just back to the cluster so i turned it on then everything worked but not the rev limiter or the speedometer. I didnt some research then I found out that I supposed connect the vss wires somewhere and I guess to cluster not ..that ground to a ground then the power to a power then the signal wire to the speedo cable from the cluster then split it to the ecu yellow N red wire but now I turn it on now the turn signals dont work and not even the speedometer or rev limiter.. so I need help it's getting real frustrating. I seen someone here talking about it about 7yrs ago and I cant see the pics.
KRock459
Oct 26, 2008 10:30 AM
spun Vtec
Apr 24, 2008 07:49 PM
