O2 sensor location issues
Old Jan 30, 2020 | 12:53 PM
jdmark1's Avatar
Default O2 sensor location issues
I've recently put on a new Cat and the bung for the downstream O2 sensor has the wiring about 1mm from the cat heat shield on the bottom of the car. It's close enough that it'll definitely burn threw the wires without protection so I wrapped the sensor and wires in several layers of aluminum foil as a temporary solution just for a few days. It works as far as heat transfer goes, but since I've done that I keep blowing one of my fuses and I'm almost positive its because the body of the O2 sensor is now grounded against the bottom of that heat shield it's pressed up against because of the aluminum foil. The best solution would be just to relocate the sensor. But other than that, is there some heat wrap/insulation I can put over the wires that'll stand up to the heat AND is not electrically conductive?
Old Jan 31, 2020 | 11:13 AM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: O2 sensor location issues
https://www.designengineering.com/cool-tube/
Old Jan 31, 2020 | 12:09 PM
jdmark1's Avatar
Do you know if that is electrically conductive?
Old Feb 1, 2020 | 11:13 AM
DaX's Avatar
DaX
Loved
Community Favorite
I don't, but I'd imagine the inside isn't. Send them an email or give them a call - they're very good folks. They have other heat protective products as well which do not have the reflective outer shell.
Colinshondturd
Jan 27, 2020 06:03 AM
EJ8 Kenobi
14
Feb 25, 2008 08:59 PM
PH3593A
Oct 13, 2004 10:14 AM
GsrTeggy
May 10, 2004 12:17 AM
:jdmshmaydm:
Sep 19, 2002 04:57 AM
