alignment pin on crank 4 flywheel? D16Y7 97hatch
Old Jan 29, 2020 | 04:07 PM
hatchaholic's Avatar
10 Year Member
Loved
Community Favorite
Default alignment pin on crank 4 flywheel? D16Y7 97hatch
There's a hole in the crank flange and in the flywheel, like a pin would align them, but there's no pin. I don't see one on my parts site but the manual references one in installing the flywheel. There were a a lot of missing things on this engine so...?
Thanks!
Old Jan 29, 2020 | 04:19 PM
muellersfan's Avatar
Default Re: alignment pin on crank 4 flywheel? D16Y7 97hatch
Part 16
https://www.bernardiparts.com/Honda/...&assembly=2075
Old Jan 29, 2020 | 08:47 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
He's talking manual transmission side of the crank. Many flywheels have a hole that lines up with a hole on the crang flange that holds either a flywheel or the flex plate.
I've never seen a pin on my 5th gens, doubt it's in the 6th gens but could be mistaken.
95 civic flywheel:
Old Jan 30, 2020 | 04:28 AM
mk378's Avatar
The D series doesn't use a pin. One of the bolt holes is off center so it only fits together one way.
Old Jan 30, 2020 | 08:04 AM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
The pin is found on F/H applications... but for B,D,K applications, manufacturers create the small dowel hole for two purposes: 1) They use it as an index point during machining to properly create the other holes needed in the flywheel. 2) When your machinist balances your COMPLETE rotating assembly, he can mark the end of your crankshaft through the dowel hole so that you can reference that position during engine assembly.
Old Feb 1, 2020 | 09:07 AM
10 Year Member
Loved
Community Favorite
Thanks for the help! In looking for pics or videos it took a long time to find even one like mine but that didn't have any pin either, just the holes.
Was thinking maybe for balance but indexing def makes more sense.
Honderachinaldo
Engine Machining & Assembly
May 14, 2019 09:25 PM
Pablomg
May 13, 2019 03:16 AM
ITR-2001
Aug 16, 2006 02:02 PM
anomale
Oct 13, 2005 07:00 PM
wutangben
Sep 4, 2002 11:51 AM
