What aftermarket "vinyl hose" should I buy?
Old Jan 27, 2020 | 05:03 AM
r_kage's Avatar
Icon5 What aftermarket "vinyl hose" should I buy?
I'm trying to replace hoses on my '95 Accord. I bought fuel hose and a variety of fuel system related parts. Unfortunately, a few are discontinued and I don't know what I should get.
1) Part #17658-SM4-000 Tube Assy Breather 260mm (This connects to the Fuel Filler Tube, which I also replaced.)
2) Part #17702-sv4-930 Hose, Fuel Pipe Return (wondering how this is different from 17704-SL4-930, other than location... can I sub one for the other)
And
Bulk Vinyl Hoses 8x12 and 12x16 which connect to the "Canister Drain Tube Joint"
The bulk vinyl hoses aren't really that essential right now since they are under the hood and not in bad shape, but the numbered parts above, I'd really like to replace with new.
Thanks!
Old Jan 27, 2020 | 01:45 PM
99stockcivic's Avatar
Default Re: What aftermarket "vinyl hose" should I buy?
Can you bring the old one with you to a NAPA store and see what they can come up with? When I'm stuck for hoses, this is where I try to get a match.
Old Jan 28, 2020 | 08:04 AM
r_kage's Avatar
That's a good idea... though I may have thrown away those ones with parts numbers. I had to cut some of them off at the time. :/
Is only the return a high pressure line?
Old Jan 28, 2020 | 09:59 AM
stin1's Avatar
Loved
Community Favorite
Acura lists the following part number for my drain tube from the canister for my integra.
95005-1200150m
This was enough hose to replace the drain tube and the upper fitted hose that is discontinued for the top of the canister.
boostontheD
Jun 20, 2013 10:36 AM
JR CIVIC
16
Jun 7, 2012 06:28 PM
boostworksny
Oct 12, 2011 07:28 PM
SilverejSi-R_g
Nov 16, 2005 09:40 AM
migo
Jun 18, 2001 06:13 PM
