oil filter housing gasket ?
Your engine oil is kept clean by passing through your oil filter as it circulates through your engine.
Between your engine and the oil filter is a mount known as the oil filter housing.
As you drive your car normally, the oil filter housing itself should never need to be replaced.
However, you might find that it develops a leak from the gaskets or it may develop a crack in the oil filter housing itself, which will require replacement.
The average cost to replace the oil filter housing is $171 to $655 depending on the make and model, and a few cars may be higher than that.
Even though the oil filter housing itself may never fail, the oil filter housing gasket is a common point of failure. Please check out with Savanah tow truck for further assistance
OP you will need to give specific motor model.
Some models come with an oil cooler and some don't. The ones that do not, the oil filter itself mates right up to the engine block. The oil filter's gasket is the only seal. The oil cooler setup has an o-ring behind it.
Rainville
15
Dec 17, 2004 07:08 AM
cokinut
Oct 13, 2003 06:23 PM
Dirt
Feb 25, 2003 11:29 AM
