Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Coil pack keeps failing
Old Jan 26, 2020 | 09:29 AM
dailyhondadrive's Avatar
Default Coil pack keeps failing
Hello,
New here, glad to be here. I have a 2001 civic w/the 1.7, i have replaced one of the coil packs 3 times in the last 12 months and about to replace it again. wrote it off to a bad coil to start with but now don't think so. Any suggestions? Btw, do have a light on, bad converter, that's it.
Thx for any help.
Vic
Old Feb 17, 2020 | 10:25 AM
muellersfan's Avatar
Default Re: Coil pack keeps failing
When the "bad" coil won't spark, does it get both battery voltage and good ground?
Haver you inspect the spark plug?
Old Feb 18, 2020 | 06:47 AM
NDNV's Avatar
Using OEM ignition coils?
Using OEM NGK spark plugs? When were they last replaced?
Check wiring to this coil.
Check your grounds too.
Old Feb 18, 2020 | 09:13 AM
Thx
Yes all oem and plug/all plugs have been changed (can’t remember brand).
just had a respected mechanic check it for me, he couldn’t find anything either. Even took it apart to make sure the timing belt was not off, it was good. He adjusted the valves, replaced all the coils, plugs again and put it back together. Been running good so far, time will tell??
zx96_r
Oct 17, 2009 08:31 AM
nanagsr
Jun 24, 2009 07:04 PM
Nerologic
Jan 29, 2007 03:56 PM
Stephdavis18
Jan 26, 2006 07:46 PM
redintegra1998
Aug 1, 2005 05:30 PM
