96 civic dx sedan p0700 & p1753
Old Jan 22, 2020 | 08:44 PM
richard203's Avatar
Default 96 civic dx sedan p0700 & p1753
hi so i just moved my civic and the check engine light came on, i plugged a obd scanner and it show p0700 and p1753. p1753 is the torque converter clutch solenoid circut problem, and p1753 is telling you theres a problem in your tranny. my question is if the wires is good thats mean its the torque converter clutch solenoid is no good?
Old Jan 23, 2020 | 05:09 AM
muellersfan's Avatar
Default Re: 96 civic dx sedan p0700 & p1753
Old Jan 23, 2020 | 07:38 PM
richard203's Avatar
do you know where i unlug the pcm connection at?
Old Jan 23, 2020 | 07:39 PM
PCM = ECU
Box behind passenger side kick panel.
Old Jan 23, 2020 | 07:44 PM
richard203's Avatar
so the connector should be brown and black color right and the pcm connector is yellow color?
Old Jan 23, 2020 | 07:55 PM
32-Pin ECU connector A = gray
You are referring to the colors of wire for testing (Yel & Brn/Blk).
Old Jan 23, 2020 | 07:58 PM
richard203's Avatar
what color is the 25 pin connector?
Old Jan 23, 2020 | 08:01 PM
Also gray, located adjacent to 32-pin ECU connector A.
Old Jan 26, 2020 | 02:42 AM
richard203's Avatar
alright i'll test it when outside is not raining. i'll update this when this is solved.
Old Oct 8, 2020 | 04:46 PM
DaSesh's Avatar
Did you ever solve??
Old Mar 8, 2023 | 06:49 PM
richard203's Avatar
nope it went away for few years and came back again. lol so now ima revive it back. seems like its always when it rain the code come out, and i saw a puddle of water in the passenger side. mybe the ecm got some water in it or the plug?
lewkrew
Jan 25, 2019 06:19 PM
Jr. Styles
Apr 2, 2017 05:28 AM
cknisley
Oct 24, 2004 03:00 PM
