Passenger side front wheel clunk
Old Jan 20, 2020 | 09:35 AM
jacksontanton's Avatar
Default Passenger side front wheel clunk
I have a small issue. I had some clunking noises while turning at low speeds from both ends, and since I dont know if they were ever replaced I put in some new axles on both sides. However, for some reason there still seems to be a clunking noise on the passenger side. The CV noise i only noticed when i put in some budget Skunk2 upper control arms. I only run -5 degrees of camber, and around 20-30 mph the car seems to shake a little bit after the new axles too. I'm sure i installed them correctly (it was a first time doing this for me). Thinking of investing in some quality control arms soon but would like it to last me a little longer.
Any help is welcome
Old Jan 20, 2020 | 11:09 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: Passenger side front wheel clunk
Do you how to test for bad ball joints?
Old Jan 20, 2020 | 11:14 AM
Lower joints seemed good when i pulled them out, but i have no idea of the mileage on them. So maybe. Havent heard of another way to test them other than moving them around when unbolted
Old Jan 20, 2020 | 03:57 PM
muellersfan's Avatar
What car?
Old Jan 20, 2020 | 04:04 PM
2000 Civic SI
Old Jan 20, 2020 | 04:08 PM
You haven't mentioned the intermediate shaft.
Old Jan 20, 2020 | 04:12 PM
didnt mess with that. but because the noise is from the passenger side i didnt think that could be a symptom
Old Jan 20, 2020 | 04:16 PM
How are you so sure? Locating noises in a moving car can be very tricky.
Old Jan 20, 2020 | 05:59 PM
Nathan937's Avatar
Without hearing the clunk, it’s a little tricky to diag online. Check bushings. On the lower control arm, sway bar bushings and end links If your car has it. Double check tighteness of the upper control arm that you installed. The two bolts that hold the arm to the body. And not sure what you meant by checking the ball joint when it’s unbolted, but raise your front end up and grab your tire. Move side to side then up and down. See if there is any give.
Old Jan 20, 2020 | 06:02 PM
thats just where it seems to be coming from. could be the halfshaft. i guess i should have just replaced that too
Old Jan 20, 2020 | 06:03 PM
will do. lower control arm bushings could be it. i guess this starts the rabbit hole of replacing more and more parts...
Old Jan 20, 2020 | 06:04 PM
Nathan937's Avatar
There’s no sense in replacing parts you don’t have too. You’ll spend more money than you want and still have a noisy car. Get the front end off the ground and start trying to see if you can move anything.
tiresias
Sep 21, 2010 10:32 PM
thanh4o8
Jul 23, 2008 09:50 PM
zach1288
Jan 15, 2007 06:32 PM
NoGreenCard
Sep 9, 2005 07:53 AM
rudeman85
Nov 4, 2004 01:19 PM
