Suspension & Brakes Theory, alignment, spring rates....
when to change brake pads?
Old Jan 15, 2020 | 10:29 PM
ginahoy's Avatar
10 Year Member
Default when to change brake pads?
I had my wife's CR-V in for an oil change. The shop reported front brake pads have 6mm remaining and recommended replacement. That seems rather aggressive. On the other hand, I obviously don't want to wait until the caliper damages the rotor. What's the appropriate thickness to replace front pads?
Old Jan 17, 2020 | 07:40 AM
aw614's Avatar
10 Year Member
Loved
Default Re: when to change brake pads?
Take a look at them yourself, and see. If it looks there isn't much material left then change them, if it does look like a little over half the material is still on then keep them on and check again in a few months.
Old Jan 17, 2020 | 09:54 AM
Tyson's Avatar
i go by the wear indicator.
i have no idea what the actual thickness is when i change them. i just change it when it says to change.
Old Jan 18, 2020 | 10:41 AM
Nathan937's Avatar
6mm seems like it still has useful life left. If your wife is anything like mine, she smokes through brakes. If your pad doesn’t have a squeal tab on it, or any wear indication take a peek for yourself. I’m not too familiar with the newer Honda stuff, but I’d say at 4mm I’d go ahead and get new pads and machine the rotors assuming your thickness is fine.
Old Jan 23, 2020 | 09:56 AM
416Gang's Avatar
They use something like this at the dealership. Get yourself one and check. Its easy and straight forward to use.
Amazon Amazon
davemem
Honda CR-V & Element
Dec 12, 2010 07:44 AM
laur
Sep 3, 2010 07:28 PM
redDAinteg
Dec 17, 2008 12:18 PM
mrdeadman
Oct 5, 2005 03:31 PM
internet ay
Apr 28, 2002 07:32 AM
