Honda Accord (2013 - 2015) 2013 - 2015 Honda Accord and Inspire
2013 Accord EX-L V6, FCW LDW ABS & other dash lights after suspension install-
Old Jan 13, 2020 | 09:51 AM
lolv8s's Avatar
10 Year Member
Default 2013 Accord EX-L V6, FCW LDW ABS & other dash lights after suspension install-
I researched the issue and found out that when the battery gets low, things like this can happen. Like all of these lights coming on. I put in Tein street advance coilovers and after the first two coilovers in the front, no issue and no lights came on. After the two in the rear, the FCW, LDW, ABS, steering wheel !, and traction control light all came on (no issues with the power steering itself). So did the (!) tire light, but it blinks. I've read about how you can do a battery cable reset, but I haven't found an instruction on how to do it with a 2013 model. Or, if that's even what I should do. Thank you all for any help!
Old Jan 14, 2020 | 07:31 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: 2013 Accord EX-L V6, FCW LDW ABS & other dash lights after suspension install-
My guess is it needs to be aligned and the system re calibrated.
Old Jan 14, 2020 | 10:23 AM
lolv8s's Avatar
10 Year Member
I could get an alignment, but how would I recalibrate? Could I get away with unhooking & reconnecting the battery, or would I need to see the dealership?
Old Jan 14, 2020 | 03:14 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Any competent alignment shop should have the tooling to re calibrate the system. It is a required function on many vehicles these days. Ask them.
(I should add that I am just guessing as to your problem. The proper procedure is to have the system scanned for codes and go from there. A dealer scan tool or equivalent is probably necessary to pull the codes from the correct systems)
Old Jul 7, 2023 | 08:33 PM
eddynava's Avatar
So what was the issue? Did you get it fixed? Im having the same issue with mine after installing new rear brake rotors
Old Jul 10, 2023 | 03:06 AM
lolv8s's Avatar
10 Year Member
​​​​​​I fixed part of it. My problem ended up being a part for the ABS pump module I had to send off and have repaired. I want you to really make sure that you're having the same issue I had because it would not be cool to do everything I did to fix it and it not be the same issue I had. Maybe post a picture of the dash with the lights that are coming on. You could have a diagnostic ran at the dealership, but that will be like $100 you won't get back if you fix the issue yourself. Dealership wants to replace the part completely (for like $3.5K if I remember the estimate correctly) instead of fixing the old part like I did (for $200).
​​​​​Please watch this video that taught me about the issue.
​​​I made another thread about how I resolved the issue. Please go to the thread below.
https://honda-tech.com/forums/honda-...ights-3370220/
Jim Yahazim
Honda Civic (2006 - 2015)
Dec 28, 2016 01:55 PM
GsDAteg
Audio / Security / Video
20
Jun 13, 2012 03:35 PM
DH757
Nov 8, 2011 05:35 PM
