hi everybody so im in the process of doing a obd1 b20vtec swap in a obd2b 1999 civic. im currently at wiring it all up but my issue right now is the distributor. obd1 distributor obd1 distributor obd1 distributor obd2b harness obd2b tach signal wire???? im not sure need help with this
my question is how to i wire this up? any pictures or diagrams would help thanks.
I also have a obd1 ecu chipped with s300
do i need to repin the harness?
In this case, you likely need to run an rpm wire from the distributor to the cluster as the stock 99 Civic harness does not have the distributor-to-cluster rpm wire.
i bought a depinning tool and now the only thing im missing is the obd2b to obd1 connector diagram
I can post OBD2B diagrams for you, but you probably just need to run a wire through the firewall hole and splice one end to the test connector blue wire and the the other end to the blue tach wire in the cluster connector.
