95 eg h22a swap fuel injector issue
Old Jan 8, 2020 | 08:06 PM
95HswappedEG's Avatar
Default 95 eg h22a swap fuel injector issue
Looking to see if there’s anyone that can guide me in the right direction to fixing my code 16 (fuel injector). It’s a obd1 jdm h22a swap out of a 92 prelude with bolt on’s, skunk 2 intake manifold, blox throttle body, intake/header/exhaust, a p06 chipped socketed ecu with a h22a basemap, and obd1 345cc peak and hold stock injectors, but whoever had owned the car previously never wired in the injector resistor box. The car is really hard to start cold, you have to hold the pedal to the floor and release it so it will fire up then pump the pedal get it going, sometimes it will backfire and the headers seem to get warm quickly anyone know what the issue may be?
Old Jan 8, 2020 | 09:45 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: 95 eg h22a swap fuel injector issue
Yeah... you need the resistor box. Alternatively, you could install a set of 5G Prelude 290cc injectors and that should get you closer to your basemap. Next... basemaps are ****... so get it tuned if you want it to run right. I am stunned at how many people actually think that a basemap is going to make their car run perfectly and complain when it doesn't. A Basemap is a STARTING point. Tuning makes your entire band of parts work in concert together.
Old Jan 9, 2020 | 03:08 AM
Base map got nothing to do with my issue, I’ve tried different ecu’s thanks. Stock ones at that, I think I have a dead injector or wiring issue with them due to not having the resistor box, my friend has a k series with bolt ons and when he got his kpro and put a base map on it, it ran way better than mine.
Old Jan 9, 2020 | 05:59 AM
muellersfan's Avatar
https://honda-tech.com/forums/hybrid-engine-swaps-18/
Old Jan 10, 2020 | 07:38 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Originally Posted by 95HswappedEG
Base map got nothing to do with my issue (It may... do not rule this out because you do not have a stock engine... the larger T/B alone causes stock ECU's to have fits.), I’ve tried different ecu’s thanks. Stock ones at that, I think I have a dead injector (While the engine runs, remove each fuel injector clip one at a time to discover which one isn't working... then MOVE this injector to another cylinder and re-test. If the problem moves, then the injector is the problem.) or wiring issue (If the problem cylinder doesn't move after moving the fuel injectors around, you need to test the wiring) due to not having the resistor box (the resistor box changes the way the fuel injectors BEHAVE, not whether they work or not), my friend has a k series with bolt ons and when he got his kpro and put a base map on it, it ran way better than mine. (Terrible comparison... KPro basemap calibrations are a much better starting point than whatever might have been burned to your 28-pin chip. If your chipped ECU runs no better or no worse than the stock P13 ECU's, then I would be looking at the injectors and wiring first.)
Take a photo of the engine harness wiring plugs on the driver's (Left) side of the vehicle and post it here please. Based on this photo, I may be able to offer up a quick and clean resistor box installation for you. How comfortable are you with a multi-meter ?
Freshmodsegh22
Jul 9, 2015 07:22 PM
Metal Head
Aug 24, 2009 06:42 AM
SpoonFed
Jul 30, 2003 11:33 PM
altoid
Feb 5, 2003 08:10 AM
Mikey3000
May 30, 2002 02:26 PM
