Which AFR gauge for tuning yourself? Is one better than others?
Old Jan 8, 2020 | 06:56 PM
Stopsign32v's Avatar
Loved
Default Which AFR gauge for tuning yourself? Is one better than others?
Going to be tuning this thing and wondering what wide band AFR gauge you guys are using. I know reading AFR is pretty cut and dry but I didn't know if one stood out from the rest.
Old Jan 9, 2020 | 03:34 AM
Txdragon's Avatar
Default Re: Which AFR gauge for tuning yourself? Is one better than others?
Innovate and AEM are 2 of the most common.
Old Jan 9, 2020 | 03:39 AM
Autoworks's Avatar
Innovate, AEM, PLX are going to be the top 3/most commonly used 3. All 3 use the same Bosch 4.9 sensor. It boils down to gauge preference,logging option, matching over anything for most.
Old Jan 10, 2020 | 05:57 PM
wunfstgsr's Avatar
Loved
Community Favorite
The Innovate MTXL is way faster and clear to read than the AEM units! my brain hurts big time looking at a AEM AFR gauge! the Innovate is very accurate and fast! just my opinion
Old Jan 10, 2020 | 06:03 PM
Chance EG's Avatar
Glowshift also has wideband gauge kits that use the Bosch 4.9
Old Jan 10, 2020 | 06:24 PM
D21X's Avatar
Same experience here. Went from an AEM Uego to MTXL.
Old Jan 11, 2020 | 05:44 AM
turboLScrx's Avatar
25 Year Member
Loved
Community Favorite
I use Innovate with a 4.9
Old Jan 11, 2020 | 05:48 AM
Txdragon's Avatar
Same here.. Innovate LC-2.
Old Jan 11, 2020 | 06:10 AM
turboLScrx's Avatar
25 Year Member
Loved
Community Favorite
‘only thing about the 4.9 sensor is it’s very sensitive to moisture, make sure to mount the bung on the top side of the exhaust pipe. E85 is bad about spitting water on start up and will burn out these sensors
Old Jan 12, 2020 | 08:08 PM
K7-1Ktrevor's Avatar
Loved
Community Favorite
I agree the older style sensors were allot more durable. Not a fan of the innovate widebands as I had issues with them throwing an e8 code even with new sensors. My aem has always done what I’ve needed it to do. I’ve been using one for the last ten years so that’s what I stick with.
Old Jan 13, 2020 | 07:40 PM
NVturbo's Avatar
O.G. triple O.G.
I'm using the AEM, with delay turn on....to help minimize any damages from condensation to the Bosch sensor.
Old Jan 15, 2020 | 02:51 PM
spAdam's Avatar
Loved
Community Favorite
PLX all day. 7 years old, over 100k miles, zero issues. Should probably get a new sensor just on principle.
Old Jan 16, 2020 | 09:25 AM
Relic1's Avatar
same here but several more years of operation (damn I'm getting old) zero issues with gauge, controller or sensor.
same here too....
Old Jan 16, 2020 | 05:50 PM
Nathan937's Avatar
how do you have the delay turn on set up?
Old Jan 17, 2020 | 08:52 AM
spAdam's Avatar
Loved
Community Favorite
I went with the PLX back when I got it because I was looking for an option that didn't require me to use a gauge. I just wanted to run it to the ecu for logging/tuning/closed loop control. Since then I've learned that their boxes are pretty good, they have low latency (important!) and are pretty reliable despite being bilt with fairly consumer-grade parts. They also don't have any reverse voltage protection, so if you accidentally hook one up backwards you will fry the box.
Other things I've picked up from too much reading:
- Innovate are hard on sensors. It seems like maybe their sensor heating strategy is not great.
- AEM makes a nice unit, but it is slow.
- Tech Edge are slow.
- 14Point7 makes a decent, simple, reliable product. Not aware of the tech specs though.
- NTK are really good controllers but use a non-Bosch sensor which is actually a great sensor but is more expensive and harder to source when you need a replacement. (Are the NTK boxes even still available?)
Interesting. Is this an option in the AEM software? We use 4.9s at work on all kinds of fuel, including E85R, and have never killed one that I know of, aside from melting the headers off an engine on the dyno or crash damage. They seem to be pretty indestructible. On car they mileage out, but on dyno they run for what seems like forever. To be fair, these are engines that don't get fired until they are warmed up with external heaters and ecus with way better control.
This is something that really sets the OEM and higher end ecus apart from the tuner grade stuff. An ecu with on-board lambda control is most likely not going to run the sensor until the engine is running, or is going to apply the heater in a more gentle closed-loop manner than an external controller can.
I have been thinking about delaying power on though, just to be nicer to the sensor. One option that came to mind would be using a relay on one of the programmable outputs on the ground wire of the controller. In S300/NepTune you could set the output to 'always on' and set it up so that the controller is powered on with the engine running (say, above 600rpm or so) and maybe above a certain engine temp if you want to warm up/dry out the exhaust before powering on. It would be a quick reprogram to have the sensor always on for things like tuning cold starts.
Old but good thread with a ton of research: DIYEFI.org Forum - View topic - Widebands That You Would or Wouldn't Buy
Old Jan 17, 2020 | 07:30 PM
motoxxxman's Avatar
pro tuner here. I can say from a few decades of tuning experience, PLX is the only wideband that reads accurately consistently. They also seem to last the longest. I have never seen a PLX wideband that was more than 0.15afr different than the motec dyno wideband. But 90%+ of all other widebands tend to read anywhere from 0.2-1.0afr different than the dyno wideband.
If accuracy is what you want, PLX is the only way to go.
Aem seems to last the longest per sensor, slightly longer than PLX, but they are horribly inaccurate.
Innovate is hit or miss, and changes every time you replace the sensor. They do tend to burn up sensors faster than most other brands though.
Old Jan 18, 2020 | 04:47 AM
Loved
So is this particular PLX the route you guys would suggest? https://www.plxdevices.com/Wideband-...7346002719.htm
Old Jan 18, 2020 | 07:00 AM
spAdam's Avatar
Loved
Community Favorite
Yeah, that’s the only one they sell. What ecu are you planning to use?
Old Jan 18, 2020 | 02:48 PM
Loved
Not 100% sure. I got it from Phearable.net and the receipt says "Hondata S300 package Pre-installed into Obd1 Vtec ECU. But I will not be going Vtec for a while if at all.
Old Jan 18, 2020 | 04:00 PM
spAdam's Avatar
Loved
Community Favorite
S300 was the answer. If you plan on running closed loop with a lambda sensor, you’ll need to wire it in to one of the spare ecu inputs... not to the direct analogs on the s300 board. I prefer EGRL since I’ll never use EGR, ELD is useful for watching your system amp draw.
stopsayingJDM
Engine Management and Tuning
Sep 16, 2012 04:44 PM
thegatekeeper14
Jul 2, 2012 02:15 PM
JACER63
Feb 27, 2007 07:51 PM
