02 Civic EX unable to start car, cranking, no power to ignition coils
Unable to start car / not getting any ignition / coils and spark plugs not sparking / no power to EGR / no power to alternator
Drove car to the store with no problems, driving normally and started normally. Car runs excellent for 200k miles. Came back to car, dead stick/not starting. Need some assistance please?
New Battery
New Spark Plugs
New Coils
New Starter
New Belts including Timing Belt (also in TDC)
New Water Pump
New Alternator
Everything plugged in / No loose wires / grounded
Fuses good under hood and under dash
I have power in the cab and dash.
dash and cluster lights up / no warning or engine light on, nor flashing.
I have power in the fuse box.
Relays under hood and behind glove box working and clicking over normal.
I have power to the starter and cranking / belts, cam and crank are turning when trying to start.
I have fuel and compression.
Tried starting it in Park and in Neutral.
Any ideas, what the problem can be?
Anything I can check that I may have overlooked?
New Battery
New Spark Plugs
New Coils
New Starter
New Water Pump
New Alternator
Yeah I already tried that, but I’m going to go try that again. I’m also going to replace the crank and cam sensors tonight. If that doesn’t fix the problem, I’m not sure what to do next?
Regarding thread title, did you actually check whether battery voltage reaches the coils?
Have you cranked the engine for 30 seconds to see whether any CEL codes are set?
Yeah I checked for voltage. No presence of any passed the PCM. I’m thinking I may have to take it in and them check, repair or replace it according to the repair manual. Also, no. I haven’t tried starting it for 30 seconds. The only good news is that the starter is turning and the motor is turning when I try to start it and I have power everywhere else
Danger_Dorn
Jul 19, 2012 04:37 AM
