Troubleshooting: Boost pressure drop during VTEC engagement - B-series Engine
Old Jan 7, 2020 | 04:40 PM
Shane3950's Avatar
Default Troubleshooting: Boost pressure drop during VTEC engagement - B-series Engine
Hey guys question.....my boost drops a soon the vtech engages...2nd gear and 4th will hold just fine...but when the vtech engage ar 5500rpm the boost starts to drop! Peak 18 and then at 7000rpm I'll drop to 13.8! Then in 4th it holds nicely at 17ish....I just do not understand the reason behind this! I have done datalogs with both with vtech and with out vtech and the nonvtech log the boost holds great...every gear is perfect but with vtech it dropps....driving me crazy!!
Old Jan 7, 2020 | 06:07 PM
turboLScrx's Avatar
25 Year Member
Loved
Community Favorite
Default re: Troubleshooting: Boost pressure drop during VTEC engagement - B-series Engine
turbo size?
wastegate vacuum source?
wastegate size?
motor?
intercooler size?
Old Jan 7, 2020 | 06:22 PM
Aradin's Avatar
Premium Member
^^ Also, what camshafts and engine? Sometimes this can be caused by extra camshaft overlap on the larger VTEC lobes. I've experienced that in a few setups where VTEC would activate and a loss of 1-2psi would be logged briefly. In your case that doesn't sound as likely. More likely related to the turbo setup.
Old Jan 7, 2020 | 06:45 PM
turboLScrx's Avatar
25 Year Member
Loved
Community Favorite
blowoff valve could be opening up also? He never said if it’s always done this or just started the problem
Old Jan 8, 2020 | 03:16 AM
Shane3950's Avatar
Both of you guys could be right...the blow off valve is on the really really solf setting and it could be opening under pressure...this has always happen
Old Jan 11, 2020 | 08:00 AM
eh2_Trav's Avatar
The logs you sent me don't look too bad. I do see the steady drop in boost from 17 psi down to 13 as you're revving it out.. If you have a restrictive exhaust manifold and downpipe setup it could be the back pressure causing the boost drop as it cannot get out enough exhaust gasses but I doubt it since you're boosting less than 20 psi.
Old Jan 11, 2020 | 03:12 PM
Nathan937's Avatar
Hey OP, what Cams are you running.
Old Jan 11, 2020 | 04:16 PM
Shane3950's Avatar
Stock z6 cams
Old Jan 11, 2020 | 04:29 PM
Nathan937's Avatar
Well That throws my theory out the window. Let us know what you end up finding on it. I wouldn’t know what would cause a drop in vtec only
Old Jan 14, 2020 | 04:45 AM
Txdragon's Avatar
Default Re: Troubleshooting: Boost pressure drop during VTEC engagement - B-series Engine
Stock z6 cams
Stock springs and such too? What's your exhaust setup?
Old Jan 14, 2020 | 04:56 AM
Shane3950's Avatar
Yea bro...stock head...just bottom is built
Old Jan 14, 2020 | 05:05 AM
Txdragon's Avatar
What engine management? Also, what are your VTEC settings for low/high load. Screenshot and put them up if and when you can.
Steeve_Civic
Dec 11, 2012 03:44 PM
Nosman_99
Apr 22, 2010 07:40 PM
delsolvtec1993
Jun 12, 2009 05:36 AM
civicboy1128
Aug 5, 2008 12:39 PM
