2000 Civic EX d16y8 Auto to Manual swap Wiring issues - Need help
Old Jan 4, 2020 | 07:13 AM
SAVAGEWARRIOR's Avatar
Default 2000 Civic EX d16y8 Auto to Manual swap Wiring issues - Need help
Originally Posted by brooksto
I did an auto to manual on my 96 ex, I did not throw any codes for the auto tranny. I am using a manual ecu with auto harness, just had to rewire/repin for the IACV 2wire/3wire difference as earlier mentioned. And I can check my codes fine so I dont know where you got the info about not being able to check codes with the 4th plug out. In my case there is no problem.
I am however getting a pesky code 90 which I am guessing is not related to the auto to manual conversion. I am still trying to track that done. I have already swapped the EVAP canister and the code comes back. Any of you have this issue?
Modified by brooksto at 7:33 AM 11/27/2003
I need help with my speed after the auto to manual swap. Can someone help me 😔
Old Jan 4, 2020 | 07:29 AM
tony_2018's Avatar
Fish Twig
Default Re: Difference between AUTO and Manual harness?
Didn't even list what your problem is
Old Jan 4, 2020 | 07:42 AM
well I have a 2000 honda civic ex d16y8 I'm using the p2p a12. Did the intake manifold swap even the wiring and plug b depin at the ecu. Did the reverse lights. Swapped out to a new vss. My gauge clusters were working before it's just the speedo that doesnt work. I even swapped out to a new vss plug. I've literally tried every thing. Even checked the fuse. I'm still using the auto harness. Wich I believe is the obd2b.
I believe the blue/white is the signal, black and yellow is power and black is ground? Well like i said i tried everything and im using my gps on my phone to read mph this is a head ache! This is to the new vss plug by the way.
