B-series Inquiry - Optimal operating temperature?
Guys I have a b16 turbo, just want to know whats a ideal temp to set the fan to come on at, currently I have the cooling system stock, oem thermostat and fan switch, fan come on at 205F and goes off at 195F
I've got mine set to come on at 185 <90mph. Have NEVER come close to anything resembling overtemp. Lol!
1/2 size dual core radiator from Go-Autoworks with a SPAL 30102029 fan on a shroud. The fan is wired with a relay and 12 AWG wire. I'm running a bottle of Water-Wetter in the coolant. I've been running distilled water in the summer and Honda Type 2 coolant in the cold months. My turbo is also water cooled, so one hose comes from the water pipe on the back of the block and the other comes from the bottom of the radiator.
This sounds like a legit cooling or sensor issue. When the fan kicks on at say, 185, it should kick back off as soon as it cools below that threshold; 184.
I’ve got mine set up for the fan to come in at 185. When being tuned, it was around 40 degrees that evening but obviously he was working the car pretty hard. It never went above 184. Factory t stat, factory fan, half size aluminum radiator (wiggleys radiator I think).
So when u guys set it to come on at 185 what temp do you set it to go off at? If it goes out at 184 the fan wud be cycling very often, I want it to cycle like how it would on the stock setup, I'm running the stock setup now, the fan switch turns it on at about 205 and it turns off at 195, I'm jus wondering if this it too hot for a turbocharged setup
I jus don't want the fan running constant or cycling too often, and if I set it to 185 it will either won't go out or cycle too often and I would have to take the thermostat out for it to cycle at 185 and 184
The settings should be changed. The components are ok, UNLESS you're having deeper issues. My cooling system is also stock and my setup is extensive.
He needs different equipment. I've never used my software to change any thermostat or fan switch settings. all came on at the appropriate time on the OEM settings with a turbocharger , although I did change hardware to support the increased cylinder pressurpresf turbocharging
Dats wat I wanna Know shodan if the stock cooling setting is sufficient for a turbocharged setup, I'm not running anything over 350whp, I have a spal fan with aluminum half size radiator double core, stock fan switch an thermostat, distilled water with water wetter, I live in Jamaica so it's hot climate all year round here
Yes, my fan comes on at 185 and goes off at 184. It does cycle, but not every few seconds. It takes the system a little bit to heat up and to cool down. I'm using OEM equivalent thermostat, and OEM fan switch, with settings modified in Hondata.
Since Shodan has a different experience with his particular setup and you want to base your questions on those stipulations, yes, you need new hardware. If you want to use STOCK hardware and have the means to change settings to work with that (Neptune RTP, Hondata S300, etc), then try that before spending money on **** you *may not* need.
I'm older school, true. However, I don't believe un pushing stock hardware past its engineered limits like the cooling system and using software to bandaid the issue.
. But you're right, experiences vary... but not by much ...
This is true... I do admit... I just was never comfortable changing settings on software, when the right hardware will consistently do its job.
.But you're right, experiences vary... but not by much ...
I run a few serious setups in Barbados. it depends on what radiator tire using, not just aftermarket vs.oem. people in the Caribbean get so messed up with duties and taxes that they can't get the good equipment and have to settle a lot of the time, cour less quality aftermarket hard equipment
