1993 Honda Civic hatch fuse 24 issue
Old Dec 28, 2019 | 12:50 PM
Tyler Ketron's Avatar
Default 1993 Honda Civic hatch fuse 24 issue
Hey everyone! I have a 93 Honda hatchback with a b20b swap. I've had an issue recently where fuse 24 would blow while driving. I would put a new fuse in and I'd be good. Recently I went over a hard bump and now every time I put a fuse in it blows instantly. I've checked the ECU, the wires, the pgmfi relay everything looks good. It doesn't blow when the pgmfi relay is unplugged. I don't believe it's the fuel pump as its a newer walboro 455 fuel pump and it has worked before after the fuse blew. Could it be a ground in the fuel tank I'm missing? Any help would be great. I'm out of a car right now
Old Jan 18, 2020 | 01:31 PM
White94coupeEg's Avatar
Default Re: 1993 Honda Civic hatch fuse 24 issue
I would check all the grounds inside the cabin and make sure you don’t have a bare wire making it ground out and blow fuse
Old Feb 5, 2020 | 05:29 PM
muellersfan's Avatar
It was the fuel pump, amirite?
Tyler Ketron
18
Dec 28, 2019 05:06 PM
Tyler Ketron
Dec 28, 2019 12:20 PM
emgjsdk1
Oct 21, 2010 09:47 PM
92hybridAccord
Apr 6, 2005 10:09 AM
13BT
Sep 4, 2003 11:27 AM
