1993 Honda Civic hatch fuse 24 issue
Old Dec 28, 2019 | 12:26 PM
Tyler Ketron's Avatar
Default 1993 Honda Civic hatch fuse 24 issue
Hey everyone! I have a 93 Honda hatchback with a b20b swap. I've had an issue recently where fuse 24 would blow while driving. I would put a new fuse in and I'd be good. Recently I went over a hard bump and now every time I put a fuse in it blows instantly. I've checked the ECU, the wires, the pgmfi relay everything looks good. It doesn't blow when the pgmfi relay is unplugged. I don't believe it's the fuel pump as its a newer walboro 455 fuel pump and it has worked before after the fuse blew. Could it be a ground in the fuel tank I'm missing? Any help would be great. I'm out of a car right now
Old Dec 28, 2019 | 01:18 PM
muellersfan's Avatar
Default Re: 1993 Honda Civic hatch fuse 24 issue
A bad ground would not cause the fuse to blow. The fuel pump is the prime suspect.
I assume the fuse blows only when the key is turned to ON(II). If so:
  1. Unplug the fuel pump.
  2. Install a new fuse 24.
  3. Turn key to ON(II).
  4. Does fuse 24 still blow?
Old Dec 28, 2019 | 01:20 PM
I was really hoping against that as I can't afford a fuel pump right now. Especially not another walboro fuel pump like the one in it. Could I maybe have jarred a wire loose inside the tank or is it just bad?
Old Dec 28, 2019 | 01:23 PM
See test I posted.
Old Dec 28, 2019 | 01:39 PM
Noted. I'll try that as soon as I get home around 6
Old Dec 28, 2019 | 01:40 PM
But if the fuel pump is the issue is it possible there are wires in the tank connecting to the fuel pump have been knocked loose by the bump I went over?
Old Dec 28, 2019 | 01:51 PM
The pump wires are external to the tank.
The pump test is pretty easy.
Old Dec 28, 2019 | 01:54 PM
I know I just don't have a battery or volt meter to test it. I'm about to unplug the fuel pump and see if the fuse blows
Old Dec 28, 2019 | 01:59 PM
Battery and meter not needed for this test.
Old Dec 28, 2019 | 02:00 PM
Gotcha I thought you meant to test the actual fuel pump
Old Dec 28, 2019 | 02:02 PM
If fuse does not blow with pump unplugged, then the pump motor is the problem and has a short to ground.
Old Dec 28, 2019 | 02:12 PM
The fuse didn't blow. Is there any way to repair the fuel pump? I can't afford a new one right now
Old Dec 28, 2019 | 02:19 PM
Most likely irreparable. Pull one out of junkyard Honda. Stock Honda pump is best.
Old Dec 28, 2019 | 02:49 PM
Update there were wires to the fuel pump inside the tank. There was an exposed wire. I fixed the issue
Old Dec 28, 2019 | 03:08 PM
Did you pinch the wire with the pump cover?
Old Dec 28, 2019 | 04:52 PM
No. It was out of reach of the pump cover. It just looks like when the pump was installed they did a bad job with the crimping because the wire was frayed on one side of the crimp, exposing it to the metal gas tank. I re crimped the wire and insulated it. Fixed the issue completely
Old Dec 28, 2019 | 04:56 PM
I've never installed an aftermarket fuel pump. Why was wire crimping required?
Old Dec 28, 2019 | 05:06 PM
I'm not sure. I shoulda taken a picture. It was just 2 halves of the ground wire were crimped together. Maybe the extended the ground wire due to the larger fuel pump and where the ground was.
Glad to hear you found a $0 fix.
Tyler Ketron
Dec 28, 2019 12:20 PM
russ.shafer
Nov 26, 2010 08:47 AM
emgjsdk1
Oct 21, 2010 09:47 PM
92hybridAccord
Apr 6, 2005 10:09 AM
13BT
Sep 4, 2003 11:27 AM
