Replace Flywheel Friction Disc?
Old Dec 23, 2019 | 06:18 PM
Malt-liquor's Avatar
Default Replace Flywheel Friction Disc?
Should I replace the friction plate on this findanza? I'm doing stage 2 competition clutch on 94' civic. I got mixed search results about weather to sand it, scuff it, get it resurfaced, ect... A new plate is $100.
Old Dec 23, 2019 | 06:54 PM
jdblock's Avatar
Default Re: Replace Flywheel Friction Disc?
The guy at the machine shop said he didn't recommend resurfacing these. Something about the step-down measurement between the height of the friction plate and the outer edge where the clutch cover bolts to. Basically, if you resurface the friction plate, the gap the clutch fits in is wider, and the clutch can slip well before it should.
You can mill the edge, but that's probably not a good idea for strength.
Old Dec 23, 2019 | 07:07 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
When I took the solid flywheel to the machine shop, they told me they almost never resurface them. They rarely is enough meat left to resurface.
From this, I learned, work in the cost for a new flywheel to do a clutch job. It's easier and has better results.
Old Dec 23, 2019 | 10:52 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
There is nothing wrong with installing a new friction plate on it... I do them all of the time. I suggest that over resurfacing it.
Old Dec 24, 2019 | 06:44 AM
mk378's Avatar
I can't tell from the picture but if it isn't worn down lower than the places where the disk doesn't touch, you could just run it.
If you machine the flywheel you also have to cut down the area where the clutch cover seats to, so the overall thickness inside is the same. There is only a couple of mm difference between new and worn out. As the others said this setup is designed to bolt on a new friction area.
Old Dec 24, 2019 | 07:00 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Do you usually measure run-out before installing a new clutch disc so as to see if there will be much clutch chatter?
Old Dec 24, 2019 | 10:51 AM
JRCivic1's Avatar
10 Year Member
Community Builder
I measure the step and compare that to the spec required for the application. Measuring run-out is easiest when the flywheel is bolted to the engine.
Old Dec 24, 2019 | 01:47 PM
chrysler kid's Avatar
I'll just add depending on your power goals you dont always need a new flywheel. Daily driver d series? I'll risk it
if youre double your original power level and already burned through a clutch, id replace the flywheel.
Fun fact, 88% or more of brake dust is actually iron from the rotor. Id imagine the same is true for a flywheel
GhettoNinja06
Honda S2000
Jul 6, 2012 08:03 PM
h8ted ek
Dec 22, 2006 07:41 PM
aZnjCC
Mar 6, 2006 07:09 AM
BoostedIntegra
Jan 15, 2004 07:59 AM
civicracer99
Aug 25, 2003 01:32 PM
