Boost drop 19psi at 4400 deadline 10psi
i am having a problem.
While tuning, found out that the boost dropps in high rpm around 7500 rpm.
Was running about 18~19 4400 psi then drops to 10psi in 7500 rpm.
any idea why?? If anyone want to see the datalogs I could send it...it just doesnt want to hold the boost at all...
Turbo del sol d16z6
.48 trim turbo (did not want to notch block)
Hondata s300
Bottom fully built (except CCS)
manual boost controller (boomba)
ebay 38mm wastegate
7 pound spring
Turbo del sol d16z6
Hondata s300
ebay 38mm wastegate
7 pound spring
Turbo del sol d16z6
Hondata s300
ebay 38mm wastegate
7 pound spring
Turbo del sol d16z6
Hondata s300
ebay 38mm wastegate
7 pound spring
