my $5 diy catchcan
Old Nov 15, 2002 | 02:49 AM
morepoop4u's Avatar
Default my $5 diy catchcan
i just used a regular can and fittings from home depot. i also used a sos scrubber and a grill as my baffle. then i sealed everything with silicone sealant.
Old Nov 15, 2002 | 02:53 AM
Brian's Avatar
Default Re: my $5 diy catchcan (morepoop4u)
Wow! Nice DIY How much did all the materials cost?
Old Nov 15, 2002 | 02:58 AM
kenji's Avatar
25 Year Member
Default Re: my $5 diy catchcan (Brian)
I'll take a wild guess and say.........I don't know..........$5 ?!?!
JFWY, look in the title
Good idea on the design. Plain, functional, simple, and to the point.
-kenji
Old Nov 15, 2002 | 03:00 AM
morepoop4u's Avatar
5 ft of hose- 2 bux
2 barb fittings-3 bux
drain plug- 1.69
can, sos scrubber, grill -free haha
jb weld and silicone-7 bux
Old Nov 15, 2002 | 03:09 AM
Brian's Avatar
Default Re: my $5 diy catchcan (kenji)
-kenji
Oh my It is too early, I think I need some coffee Thanks
Old Nov 15, 2002 | 04:32 AM
Tbone's Avatar
When that clear hose heats up and is under vacume it will pinch itself shut.(if your running it inline with your pvc)
Good diy though What was the can itself before you butchered it?
Old Nov 15, 2002 | 04:33 AM
ill phil's Avatar
Nice, I like the cheapness Have you put it on yet?
Old Nov 15, 2002 | 04:48 AM
Doctor CorteZ's Avatar
not trying to be a dick but you could have put the fittings where they would keep out more vapors.
and FYI , I ran the same exact design on my car for a bit , it melted after a 20 min session at CMP.
oh and those hoses suck , they will collapse when warm.
Old Nov 15, 2002 | 04:50 AM
Tommy_Gunns's Avatar
I made my own once. It was so ugly, someone felt sorry for me and gave me a Cusco one...haha!
Your's looks nice.
Old Nov 15, 2002 | 05:06 AM
BSQ's Avatar
BSQ
Default Re: my $5 diy catchcan (Tbone)
I would have to agree. I used the same clear hose and they eventually collapsed. Go buy some 3/8" (ID) black rubber fuel hose.
Old Nov 15, 2002 | 05:28 AM
Dr Pooface's Avatar
Default Re: my $5 diy catchcan (Doctor CorteZ)
Where?
Old Nov 15, 2002 | 05:38 AM
Default Re: my $5 diy catchcan (Dr Pooface)
Where?
opposite each other , those are very close.
the imput on the can should be low , and the output of the can should be opposite and up as high as possible.
its logic , gravity works wonders.
Old Nov 15, 2002 | 06:39 AM
CW-ITR's Avatar
"quote:
Where?
its logic , gravity works wonders."
I couldn't have said any better.
Old Nov 15, 2002 | 07:27 AM
Default Re: my $5 diy catchcan (CW-ITR)
well thank you.
[Modified by Doctor CorteZ, 7:31 PM 11/15/2002]
Old Nov 15, 2002 | 08:52 AM
BSQ's Avatar
BSQ
I don't know if I agree with having the input low. Why you ask? Remember that the can will fill up with oil. If the inlet/input is to low, it could be "covered up" as the oil level rises. This would cause the inlet/input tube (the tube that connect the PCV valve to the catch can inlet/input) to fill up with oil. This would also not allow the blow-by vapors to be pulled out of the crankcase properly. Agree or disagree?
The catch can should contain some type of internal baffling to help seperate the oil droplets from the blow-by vapors.
Old Nov 15, 2002 | 10:30 AM
Default Re: my $5 diy catchcan (BSQ)
by low I meant simply lower than the output side , say maybe two inches
I left plenty of room for mine to fill up and not affect the fittings.
Old Nov 15, 2002 | 09:52 PM
morepoop4u's Avatar
haha an old tea can
i put the fittings like that because thats the only way i could fit the can in the engine bay. i'll take a pic of it installed later.
Good diy though
Argh, i thought i read something about that before. thanx
[Modified by morepoop4u, 6:53 AM 11/16/2002]
Old Nov 15, 2002 | 09:54 PM
itr1244's Avatar
did you install it on your car yet? tests? reviews?
will you make me one?
Old Nov 15, 2002 | 10:11 PM
TDRacing's Avatar
Default Re: my $5 diy catchcan (itr1244)
sorry fo the stupid question, but why the baffle?
Old Nov 15, 2002 | 10:13 PM
Reid's Avatar
Global Moderator
Default Re: my $5 diy catchcan (TDRacing)
Without a filtering element, it doesn't function as a catch can.
Instead it'd just be a useless can in your engine bay.
Old Nov 16, 2002 | 06:23 AM
BSQ's Avatar
BSQ
The baffling helps to seperate the oil droplets from the blow-by vapors (see diagram below). If the oil catch can doesn't have baffling, it will not do a good job of seperating the oil droplets and they will just be fed back into the intake manifold.
Old Nov 16, 2002 | 11:52 PM
it will nearly crimp itself shut in a short period of time.
if its straight you're fine but any bend will deform itself with heat...
Old Nov 17, 2002 | 12:09 AM
iH8RICERZ's Avatar
BSQ gets a for that!!
sikefcrx89
Jan 31, 2011 02:45 AM
*Boostwerks*
Sep 27, 2005 01:23 PM
FERIOkid
75
Jan 3, 2004 10:30 PM
JSTOCK
May 1, 2002 07:13 PM
lotus
Dec 12, 2001 07:06 AM
