I have a 1995 Del Sol which is literally bare bones. I have no A/C, power steering, power windows. The previous guy must removed everything except the head unit.
I would like to know if I could use normal civic parts like A/C and power steering without having issues.
The things I need is power steering, A/C, window motors, Wiper motors, switches and wiring harnesses
The interior is shot and you can see how the previous owner put a crank handle for the window...
I managed to find a headlight, literally the thing every ricer does...
Re: Are civic parts interchangeable with the Del Sol?
Originally Posted by NVturbo
A/C components (lines, condenser, compressors, etc)….YES
Power steering...not sure
window motors....NO
wiper motors....NO
switches....duh...NO
wiring harness....doubt it
What if I got a donor EK civic (1998) and transferred, for example, the entire wiper system or window controls, just need to fabricate switch panels but I wouldn't need to worry about different types of harnesses
Don't waste your time. I ordered a used "Del Sol" wiper motor and when I compared it to the old one, it was clearly one from a Civic. As for switches and panels, good luck with that. The doors of the EK Civic and Del Sol are not the same .
Originally Posted by JRCivic1
Your Del Sol has Civic front end bodywork.
The previous guy couldn't find a front end, so he converted it to a civic. I checked it out and the bolts and fasteners actually match the del sol ones
