1992 eh3 was driving then died out of nowhere
Old Dec 7, 2019 | 08:27 PM
Tortugax626's Avatar
Default 1992 eh3 was driving then died out of nowhere
Hey guys I’m in need of help again. So I was driving my car at around 40mph then all of the sudden, my motor quietly stopped working and lost power. I pulled aside. I don’t think it’s the alternator because it still cranks strong but won’t start. Also, before it died there wasn’t any lights dimming or flashing uncontrollably. I checked my dizzy for sparks but there’s none so I’m thinking it’s that. But not sure. Any help be appreciated I love my baby and don’t want it to stay there
Old Dec 7, 2019 | 10:13 PM
Default Re: 1992 eh3 was driving then died out of nowhere
Okay I’m pretty sure it’s the distributor by this point. Question is can I use any distributor from the civics 92-95? Can it be from other models civics as well?
Old Dec 8, 2019 | 05:52 AM
muellersfan's Avatar
Check for CEL codes and whether the timing belt snapped or stripped before you replace the distributor.
Old Dec 8, 2019 | 06:32 AM
There’s no cel and okay I’ll check the belt when I go see the car today
Old Dec 8, 2019 | 06:34 AM
Verify that the CEL works, if you haven't already done that.
Regarding the timing belt, the distributor rotor should spin when you crank the engine with the distributor cap removed.
Old Dec 8, 2019 | 07:40 AM
How do I verify the cel works? A couple of weeks ago, the cel lights came on while driving so I pulled over and restarted my car and it never came back on ever since then. I also tried retrieving any cel codes by jumping the harness with a paper clip and there wasn’t any codes. So I’m pretty sure the cel lights would work if there was a code...
Old Dec 8, 2019 | 08:01 AM
Sounds like the CEL works, but next time the CEL turns on while driving, pull over and jump the service connector without turning off the engine. This will allow you to read the code.
Old Dec 8, 2019 | 08:23 AM
Okay next time it comes on I’ll try retrieving it. With that being said, I’m picking up a distributor from the salvage yard today hopefully it’s a good working one and I’ll slap it on hopefully by tonight I’ll let you know if it’ll work or not
Old Dec 8, 2019 | 08:28 AM
Does the rotor spin when you crank the engine?
Old Dec 8, 2019 | 08:36 AM
I haven’t tried starting it to see if the rotor spins or not. I work a decent miles from where the car is right now and the junkyard is close to me right now and they said it’ll be 20 bucks so if my distributor does work at least I’ll be 20 dollars deep. I’ll still check once I get to my car tonight
Old Dec 8, 2019 | 08:40 AM
Oh and I’ll also check the belt as well
Old Dec 8, 2019 | 06:15 PM
Okay so I replaced the distributor and it worked! But, my fuel pump primed about 50% of the time so I checked the main relay and there was a lot of bare wires exposed so I’m expecting that’s the problem...
Old Dec 8, 2019 | 06:20 PM
Maybe. Fix the wires and go from there.
Old Dec 10, 2019 | 04:32 PM
Okay today I taped the wirings and everything went fine. Then I noticed that I have a surging idle again when at a stop... it fluctuates between like 700 to like 1200 rpms. Last time that happened, I bled my coolant and it went away and ever since I replaced my distributor it happened again... is it the dizzy? I didn’t do any ignition timing because the advance/retarding was dead middle so I used that as reference when I put the other one in. I’m going to bled the coolant again and see if it goes away
aznboi_106
10
Jan 3, 2012 01:04 AM
Civic_CRX_90
May 6, 2006 12:34 PM
showstopper2178
Apr 6, 2005 08:42 AM
FERIOkid
29
Jul 21, 2004 03:28 PM
LB CRX
Jul 24, 2002 08:14 AM
