Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Had tranny trouble replaced with a used and it slips, shifting hard from 2-3rd.
Old Dec 5, 2019 | 01:35 PM
jackz's Avatar
Default Had tranny trouble replaced with a used and it slips, shifting hard from 2-3rd.
Had tranny trouble replaced with a used one. It slips, shifting hard, from 2-3rd. How hard is it to rebuild
Old Dec 7, 2019 | 03:39 PM
benchwarmer's Avatar
5 Year Member
Default Re: Had tranny trouble replaced with a used and it slips, shifting hard from 2-3rd.
You replaced an old worn tranny with an old worn tranny . What have we learned ? ?
Old Dec 9, 2019 | 10:41 PM
Civvy66's Avatar
Can't argue with the post above. BUT: it's not definitive or truly helpful. More in the category of "snark" that makes forums live or die...
For you:
Drop in 3 to 4 oz. of Chemtool B-12. Run it a few days, see what happens.
If it makes a difference, then drain the pan and replace with three quarts of Lubegard ATF, 69032. $23 delivered from Amazon.
This procedure cured my shift flare and restored shift points to where they should be. This was on a 2003 LX 1.7, 183k on the odo. Now drives very, very well. I am well capable of being snarky, but I'd rather be helpful.
Old Dec 10, 2019 | 04:14 AM
5 Year Member
My apologies but to go through the work of replacing a tranny with something used with an unknown history is a bad decision . good luck with the remedy though . The powers that be would like to see any car over 10 years old off the road , then we'll be stuck with their over kill tech garbage . It's only a matter of time .
Old Dec 15, 2019 | 12:25 AM
Civvy66's Avatar
100% agree, sorry if I came across differently.
I have not had to rebuild one of these transmissions yet, but I've done nastier ones and it's just a better policy to pull the failed unit, rebuild it properly, and then take care of it well. Swapping bad-for-unknown (but known to fail!) is just an automotive version of Russian Roulette...
Old Dec 15, 2019 | 05:30 PM
jackz's Avatar
thank you I am going to try the chem stuff
Old Dec 15, 2019 | 06:07 PM
5 Year Member
You've nothing to lose, one thing people will recommend is honda ATF , I went with napas' LV ( roman #'s ) , a purest would get the OEM for not much more , once you put the chems. in how will you get them out ?
Old Dec 18, 2019 | 08:35 AM
jackz's Avatar
I wasn’t sure if which chem tool to buy the one for fuel or motor didn’t see any for tranny specifically
Old Dec 18, 2019 | 12:29 PM
Civvy66's Avatar
B-12 is the one. SeaFoam makes a Trans-specific solvent called "Transtune" but I don't think it's any different than straight-up SeaFoam except died red. I would just get the B-12 because its always a fair bit cheaper and it's a bit stronger.
I also would recommend giving the Lubegard ATF a try; I am using it to help it run a little cooler and protect the seals (the ester based synth oil does that).
ITRICED
Nov 9, 2009 07:39 PM
Laosakademiks
Mar 26, 2007 09:03 PM
Kazmans94cord
Apr 11, 2002 01:34 PM
