how to connect o2 sensor to Speed Factory obd0 to obd1 Jumper Harnes
Old Dec 2, 2019 | 04:13 AM
nexsus5 mobile's Avatar
Default how to connect o2 sensor to Speed Factory obd0 to obd1 Jumper Harnes
Old Dec 2, 2019 | 08:51 AM
Default Re: how to connect o2 sensor to Speed Factory obd0 to obd1 Jumper Harnes
Wich cables i need to connect to o2 sensor?
Old Dec 3, 2019 | 08:41 AM
4drEF's Avatar
Keyboard Humorist
really? if you have a hand full of wires and no instructions then the only way you are figuring this out is by tracing back to the pins on the ECU.
Heater (ECU A6) might be orange
Signal (ECU D14) might be grey
+12 Volt (ECU A25) might be yellow
Ground (ECU D22) might be green
Old Dec 3, 2019 | 05:00 PM
Thanks for your replay. Appreciated.
Also can i kept the original injector or i have to change with obd1 injectors?
alcidespn
May 15, 2018 06:27 PM
cwritten
Apr 29, 2011 06:30 AM
h22lude317
Jun 3, 2009 09:54 AM
integlude
Aug 16, 2004 11:51 AM
