EG auto to manual swap idle surging
Old Nov 28, 2019 | 02:44 PM
LimpSalamander's Avatar
Default EG auto to manual swap idle surging
I have a EG sedan with the original P28 auto ecu, auto manifold and throttle body and original z6 engine.
Recently I put in a 99 EX 5 speed transmission in the car because the automatic lost reverse gear and I have an EK parts car that had almost everything I needed (besides the engine and intake manifold and the ecu fix which I sold a couple years ago unfortunately)
The EG with the 5 speed swap drives and shifts fine but it has that dreaded idle surge, I've read everything I can find about the IACV wiring and the ecu and I'm honestly still confused, I just don't have much experience with wiring.
What I need to know is what exactly I need to do to fix this idling issue, would a new intake manifold, throttle body and rewire the 3 wire iacv to a 2 wire iacv and a manual conversion on the ecu fix this? Or is there other alternatives that are more inexpensive because I'm on a really tight budget atm with christmas coming up soon.
Cheers
Old Nov 28, 2019 | 09:52 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: EG auto to manual swap idle surging
Did you only swap in the '99 Civic EX manual transmission or did you swap in the engine AND transmission ?
Old Nov 28, 2019 | 11:47 PM
I just swapped the trans, I still have the original Z6 engine
Old Nov 29, 2019 | 07:11 AM
mk378's Avatar
All the OBD1 is two wire you should have a 2 wire IACV already and not need to change anything there. You will need to replace ECU or move the programming resistors inside so it doesn't throw transmission codes.
Old Nov 29, 2019 | 06:45 PM
So if I move those resistors in the ecu that should make it idle right or are there more strings attached?
Old Nov 29, 2019 | 10:37 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Nope. Swapping the transmission has absolutely nothing to do with the engine function. You have either experienced an unrelated and untimely failure that is totally coincidental OR you have created this issue with something else that you have changed during the process of swapping out the transmission. Think hard... what else did you change ?
Old Nov 30, 2019 | 03:11 PM
So I did the ecu changeover on my auto ecu and now I have no check engine lights and she idles like a dream, thanks so much for your help man
Claydooo
Mar 27, 2019 12:37 PM
esean93
21
Jan 21, 2009 05:02 PM
JokerX-1.6T
Aug 22, 2006 07:59 PM
Spectral49
Nov 18, 2003 11:50 PM
