Suspension & Brakes Theory, alignment, spring rates....
Upper Wishbone Bolt Broke Replacing Strut - HELP !!
Old Nov 27, 2019 | 09:21 AM
FRTAG's Avatar
Default Upper Wishbone Bolt Broke Replacing Strut - HELP !!
I am replacing the struts on my 2007 Accord V4. I did the right side without problem. When I started the left side the head of the top bolt on the wishbone clamping the strut broke. How can I get the old strut out if it is attached to the wishbone?
Thanks,
Fred
Old Nov 27, 2019 | 10:06 AM
Tyson's Avatar
Default Re: Upper Wishbone Bolt Broke Replacing Strut - HELP !!
lets see, youre talking about one of #12?
yeah, sawzall is probably the right tool of destruction here.
Old Nov 27, 2019 | 01:40 PM
FRTAG's Avatar
No. This part. The wishbone clamps on to bottom of strut and connects the control arm. I think it is called a Damper Fork.
Old Nov 30, 2019 | 09:21 PM
egsleepercivic's Avatar
probably have to drop the lower control arm out of the way, then remove the axle
remove the strut with the fork still on, then on the bench drill out the bolt of replace the fork
you are talking about the bolt that pinches the fork on the strut right ?
Guin-Teggy
May 22, 2010 01:15 PM
huge230
Aug 24, 2005 07:13 AM
handa
20
Jun 13, 2005 06:46 PM
komat
20
Dec 26, 2004 10:04 PM
user 98292739
Oct 20, 2004 06:20 PM
