H23a1 automatic transmission same axle as f22a1 automatic transmission axle?
Hello Honda guy. I have a question. So I was looking into purchasing a h23a1 automatic transmission for my f22a1 motor. I was wondering if I can re use my f22a1 axle for this h23a1 transmission? And if I need anything else to get this done or will everything hook right up/bolt right up?
Same axles. Should be a fairly straight forward swap. Gear ratios are the main difference. Cases and all are the same.
For the driver side axle, the cars running a half shaft have a different output seal there.
so if you put in a trans from a motor that had a half shaft, you must replace that seal with one designed for your axle.
killsnake562
Oct 9, 2008 10:19 PM
