need some advice/info for a h22 swap
hello, ive got a 92 accord ex and my current engine (original from factory with 400k on it) is more or less done for. so ive decided to swap out for an h22 due to parts for that being much easier to get locally where i live and that engine costing me the same to buy as an f22. heres the situation. my accord is a daily beater im sure most wouldnt bother with the effort for. but its been good to me for a long long time and i just cant afford to buy anything that would be any better. so i find myself in need of some advice. with my super tight budget i can get the h22 from a 2000 prelude (obd2 if im correct, and my car is obd1). that in mind id have access to the entire donor car i can pull any and all wiring i may need, ecu, just anything if i need it its mine. i can also try to track down a specific ecu if needed. so basicly if anyone can help me out with info or point me to some stuff that may help that would be great, i keep finding different info throughout forums and searches and nothing specific to what im trying to do. ive got a few days to figure it all out, also if it makes any difference im keeping the factory auto trans for now atleast ill have to see how it does and might change it later on, but for now the priority isnt performance its getting my car going again and being reliable.
If you're on a super tight budget then don't get the H22. Swap in another identical F22. There are a lot of hidden costs involved in an H22 swap. Even if you got the H22 for free you would still have at least $500-1000 into it if you did it right.
yea, i kno a direct replacement would be cheapest/easiest, but last time i checked there was only obd2 f engines locally, and ive put an add out looking for a direct replacement but not had luck getting one. so wouldnt that be the same troubles anyway? like to get the obd2 engine working in my car i mean? when i go to get my engine in a couple days i will look again at what there is, i just figured if i can only find and obd2 engine with my time frame and budget why not go for the better option.. like i mentioned i can get all the wiring if things are different and if i have to do some spliceing and stuff thats all fine. its kind of a bind i know
Pick up another F22Ax from an importer. It'll be a lot cheaper and simpler in the long run. If the car has 400k on it it's not worth putting an H series into it or adding any sorts of power because that is just going to bring out all kinds of gremlins with worn out suspension components, etc. With the extremely long geared automatic transmission you will not really be able to take advantage of the extra power anyway. Additionally in my years of experience with these engines, any USDM H22 is usually in need of a rebuild before being worth swapping. They like to eat up rings and burn a fair bit of oil at fairly low mileage compared to other Honda engines of the era due to the cylinder sleeve material.
If you are strictly limited to whatever is local to you for whatever reason, the original OBD compliance of the engine does not matter. The long block does not care if it's run on OBD1 or OBD2. You would simply use your original alternator, harness, distributor, ecu(if swapping a non-vtec engine, if F22B1 or F23 is used, a 94-95 Accord EX ecu is a good fit) and fuel injectors to make the engine compatible with your vehicle relatively easily. However there were no OBD2 options for your vehicle so you would be looking at an F22Bx series or F23 engine. Either of those would require some small changes to fit because the intake and exhaust manifolds are slightly different from your original F22A series engine but it would still be significantly easier than doing a full H swap.
ok that helps, theres lots of obd2 f engines, so if its just those few parts that makes it much easier and with any luck ill find a good one. i am also redoing the entire brakes and front end with parts ive picked up over time so ive finally run out of resons to procrastinate that haha thanks again for the simple explanation
RiceFed
Jan 9, 2006 07:28 AM
Katman
Oct 24, 2004 01:42 PM
-Bionic-
Apr 20, 2004 04:07 PM
