Suspension for a 300whp build?
Hey guys, new guy checking in with little to no knowledge on this platform. Just full sending like an idiot.
anywho, I want to have my suspension set up properly for a 300whp 1996 civic hatch build. My personal preference is a stiff ride, not sure why but it makes me feel planted to the road!
what would you guys recommend I upgrade? Budget isn't much of a concern for me, I'm honestly not sure what would be good to upgrade and what would be a waste of money.
Sorry if the post sounds confusing, I'm just as confused as you are...
what would you guys recommend I upgrade? Budget isn't much of a concern for me, I'm honestly not sure what would be good to upgrade and what would be a waste of money. Sorry if the post sounds confusing, I'm just as confused as you are...
Koni Yellows dampers w/ Ground Control Coilover sleeves ( 450F/350R spring rates)
Progress CS-II coilovers with same spring rates above
Yonaka --- GARBAGE
Function+Form --- same GARBAGE
Yonaka --- GARBAGE
Noted, thank you. how about sway bars and what not? The purpose of the build is just to be a DD but I feel comfort in knowing I can depend on my suspension when I send it. Like I'm not sure if things like camber plates would be necessary, that's where I get confused
New OEM bushings, maybe ctr sway bars with subframe brace (to prevent tear out),
also consider brake upgrades, you will want to stop that 300hp hatch.
my old setip was AMR 650F/550R with Hyperco Springs, was really planted! Swift also is a top tier spring.
Fortune Auto, Ohlins, Bilstein are a couple other options.
edit:the lower you go the more necessary camber arms become.
OEM over aftermarket bushings?
this might sound dumb but, how many pieces are in the suspension? I'm trying to get an idea of just what to upgrade
Go to hondapartsnow.com put in your car info and it will give you breakdowns of all components and what is sold individually and what is sold as sets. This will give a great visual of what all is in there.
DCH Automotive Parts of Temecula
These guys have great prices and if you're in North County SD, you could even pick them up and save shipping.
The front lower control arms failed first, the bushings connected to the subframe. The shock bushing was starting to separate too. I still have the compliance bushings in, they seems okay, but I’ll likely swap them soon. The rear lcas held up better, when i pulled them the bushings seems intact, a friend was goimg to try them ,but he wrecked the car so never got to keep pushing them.
and yes, suspension was fully loaded when torqued.
Libertariat
Suspension & Brakes
701
Sep 13, 2019 08:36 AM
sexynuts(.)(.)
Suspension & Brakes
Feb 16, 2005 05:21 AM
