Alternator upgrade
Will a Acura legend alternator work with my crx hf 91? I can modify the bracket to fit and the wiring if I need to. The legend alternator has a higher output and I know they have different belts, will the engine be able to keep the alternator working? I need an alternator upgrade the stock one at 60 amps isnt enough to power what I need it to power. Thanks in advance.
im guessing your a bass lover?
so to point you to the right place you can get higher output alts for your crx without having to try some from different cars
they do make the 90 amp ones just for the sound system lovers
and yes if you choose to just ignore getting the right alt
then yes the legend one after you modify the bracket and wiring will also work and yes your engine will keep it working
tim_r95
Jan 27, 2015 08:02 AM
CrazyModGSR
Audio / Security / Video
Jan 14, 2005 06:12 PM
