1992 eh3 cold start surging idle issue
Old Nov 17, 2019 | 07:14 AM
Tortugax626's Avatar
Default 1992 eh3 cold start surging idle issue
Sometimes when I start the car cold, the rpm would idle between 1k to 2k for several seconds and it’ll idle normally after. Is this normal? I’ve cleaned my IACV and bled the coolant and that fixed the other idle problem I had when stopped at a red light. Any tips are appreciated
Old Nov 17, 2019 | 11:10 AM
chrysler kid's Avatar
Default Re: 1992 eh3 cold start surging idle issue
Be sure to clean your throttle body and air passages. Idle surge is normal to some extent on a cold start as the car adjusts to air temperature readings. Front oxygen sensor readings can also effect idle
Pezgoon
43
Oct 24, 2014 03:27 AM
95Sedan
Oct 11, 2013 03:29 PM
95SiPrelude
Apr 2, 2009 05:31 PM
