Troubleshooting: loose clutch pedal after 1 hr of driving in a 96 integra gsr
Hi I'm looseing half my clutch pedal pressure when my car warms up. I have replaced the slave cylinder and put on a braided clutch line and it still does it. Can it be my master cylinder even if it's not leaking. Or can it be something with clutch or pressure plate. Like I said it's perfectly fine until about an hr of driving it looses half of the pedal travel. And then when it cools down overnight it's fine again. Has any one ever had this problem because this is killing me. Thanks for any help
sounds like heat related. When was the last time you replaced the clutch/PP? If you have recently, likely you didn't thoroughly clean the flywheel during the install.
redline7
Feb 23, 2008 08:53 PM
