Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2004 civic no spark ,.
Old Nov 15, 2019 | 01:38 PM
benchwarmer's Avatar
5 Year Member
Default 2004 civic no spark ,.
I checked for spark and had none , each coil has a black wire , black/white and a 3rd for each cylinder . Does anybody know which of these do what , where the coil primary gets a signal or what the problem may be ? Cam and crank sensors are new , ( unrelated )
Old Nov 18, 2019 | 04:55 AM
NDNV's Avatar
Default Re: 2004 civic no spark ,.
Did you check the #1 (15A) fuse in the Under-Dash Fuse/Relay Box?
Old Nov 19, 2019 | 05:43 AM
5 Year Member
Yes I did it's good , I connected with the ECU with a scan tool and there were no codes , there's power on the black/white wire and the black is a ground , I tested the primary coils ( I think ) and they are identical ohm readings , not completely sure how the circuit works though .
Old Nov 20, 2019 | 05:20 AM
NDNV's Avatar
Check and clean your main grounds.
Old Nov 20, 2019 | 06:34 AM
5 Year Member
batt. neg. cable is new OEM part and engine to chassis are good also , been advised to check injector pulse (weather permitting ) , I think if there is none it may point to a bad crank sensor , Also may be the ECU not sure , may have it tested at the dealer , taking pot shots here but open to any advice .
Old Nov 22, 2019 | 10:28 AM
NDNV's Avatar
There is a 3rd ground from chassis to trans.
The alternator bracket bolts need to be tight for proper grounding of the alt too. They can loosen and cause issues.
Old Nov 24, 2019 | 06:12 AM
5 Year Member
I checked for injector pulse and there was none , no spark & no pulse points to a bad crank sensor , it was put in new over the summer so it's not what I wanted to hear . Main relay is good on account of power to the coils ( black/white wire ) and the CEL light coming up with key on engine off , no codes present . I'll have to pull the lower cover and see what's up , maybe a bad wire connection .
Old Nov 26, 2019 | 01:31 PM
5 Year Member
I put an old crank sensor in and it started up , the one I took out was new from the summer when I was doing the water pump . Figured I'd replace it because it's kinda buried but the thing didn't even last a year . You can get to it by pulling the lower timing cover away after the crank pulley comes off . The guy at where I bought it says I should have got it from the honda dealer . They probably won't give me the $$ back just another crappy crank sensor .
davidayala831
May 22, 2016 08:53 AM
Nikpan
Aug 18, 2013 03:50 PM
4potnick
11
Sep 23, 2007 12:01 AM
VegaS10
Oct 7, 2005 02:53 AM
turbotime
Sep 30, 2003 03:24 PM
