YS1 vs Y1 for highway cruising?
Hi all, ive got a b18b1 swapped ef hatch with a jdm y1 transmission. It revs super high on the highway so im looking at getting a ls ys1 to swap in instead. The final drive of the y1 is 4.266 with a fifth gear ratio of 0.870. The ys1 has a final drive of 4.400 and a fifth gear ratio of 0.742. I just dont know what this means as far as rpm. Will swapping to a ls ys1 transmission from a 90-93 integra help lower 5th gear cruising speeds? Right now im at 3500 rpm at 60 mph. Thanks in advance!
I'm not sure about the case numbers on the tranny's, but a 90-93 LS transmission would be perfect for the B18B1 if you need the cable clutch. If you have a hydro clutch than get a '94-'01 LS tranny. A stock LS transmission will be at 3200rpm at 70mph fyi.
Yeah I need it to be a cable clutch. When you say a stock ls transmission will be at 3200, do you mean the 90-93 or the 94+ transmission?
If it's your daily, by all means swap to the LS Trans. If it's just a weekend car or for fun, I'd keep the Y1 trans. She'll rip a lot better with it. I drive my DC4 to work once a month and by the time I get to work, my teeth are rattling.
dailydrivenb18
Transmission & Drivetrain
Nov 16, 2019 04:32 AM
a1320honda
May 21, 2013 09:11 AM
