Theft recovered 05 type S- need ECU, immobilizer, key help
Old Nov 14, 2019 | 08:40 AM
krispykeme's Avatar
Default Theft recovered 05 type S- need ECU, immobilizer, key help
Hi
A friend of mine and me is considering getting an RSX type S project. We found a car that is missing the ECU and ignition (2005). As far as I know that the ECU, immobilized, and key needs to match.
Could this be possible to have a none dealer program it? Don’t want to tow the car to dealer. Because it’s missing a lot of other parts and we don’t want to buy if the car can’t be started
Old Nov 14, 2019 | 08:48 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Theft recovered 05 type S- need ECU, immobilizer, key help
As long as the non-dealer has a high end diagnostic computer that can marry replacement ECU's, keys and immobilizers... yes, it is possible and you do not have to take it to the dealer.
Old Nov 16, 2019 | 10:44 AM
krispykeme's Avatar
thank you
if I was able to get match ECU, ignition, and keys. It should be plug n play right?
Old Nov 16, 2019 | 07:57 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Originally Posted by krispykeme
thank you
If you use the matching key, immobilizer ring and ECU... yes, it should be plug and play.
Old Nov 17, 2019 | 10:01 AM
krispykeme's Avatar
Thank you so much.
really really appreciated the help.
the immobilizer ring is the ignition switch right?
if that is the case- as soon as entire pkg arrives. It should start.
once again- thank you
Old Nov 17, 2019 | 08:57 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Thank you so much.
It is attached to it... so it may come with the switch you have ordered. It is a black device with a ring that surrounds the key slot in the ignition switch. Without any ONE of the three pieces (key, immobilizer ring, ECU), the system doesn't work and must be programmed to mate all three.
Old Nov 20, 2019 | 09:52 PM
krispykeme's Avatar
so based on picture below I should be good then.
thank you so much
Old Nov 20, 2019 | 10:12 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Yes, that photo has the immobilizer ring.
TheVMan
Aug 10, 2013 12:38 AM
Smash03
Nov 7, 2009 07:27 PM
ep4life
Aug 28, 2008 09:47 AM
Neos
Jan 15, 2006 06:33 AM
JoeyBallzSI
Apr 25, 2004 05:13 PM
