What size injectors and Fuel pump. Also a good (cheapish) ECU/ECM
Old Nov 13, 2019 | 06:33 PM
CodyF74's Avatar
Default What size injectors and Fuel pump. Also a good (cheapish) ECU/ECM
Hey I’m looking to do a turbo on my 2000 Honda Civic ex. It is the D16Y8 motor and I would like to put at least 8-12 lbs of boost. What size injectors and what lph fuel pump would be good. Trying to reach 300+whp if possible. Also what is a good affordable ECU/ECM to get. I will be doing a full tune on the car afterwards on a dyno
Old Nov 13, 2019 | 08:49 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: What size injectors and Fuel pump. Also a good (cheapish) ECU/ECM
For conventional fuel, you will need 550cc injectors and a high pressure 255 lph fuel pump or larger to reach your target of 300 whp. For your ECU, get a Hondata s300.
Old Nov 14, 2019 | 03:19 AM
NVturbo's Avatar
O.G. triple O.G.
First and foremost, how healthy is the motor and tranny? If the engine is so-so and tranny is acting up, I would put money and effort into resolving those 2 before thinking of boosting it.
EG-SIXV-TEC
Jun 14, 2012 12:33 PM
zach1288
Sep 4, 2008 12:03 PM
Teluan
Aug 29, 2001 09:04 PM
