Rod length
B18b1 block w/ b1 crank. C1 head. Getting low comp pistons but i dont know if I need to get Different length rods to match the gsr head.
You ll be fine with that setup depending what pistons you use.
I ran a ls crank, ls rods with Usdm type r pistons in a gsr block with gsr head and had no clearance issue at all. I would put my compression at around 11.2-11.5cp with the head milling too.
any higher than that I wouldn’t risk unless you building a track car and using meth kit.
Mfoehrkolb
Nov 21, 2007 05:37 PM
