92 civic hatchback b16a clutch issue
Old Nov 9, 2019 | 09:27 PM
alexzhere's Avatar
Default 92 civic hatchback b16a clutch issue
I have a 92 civic hatchback with a 1st gen b16a swap, s1 transmission with a cable to hydro conversion. The clutch pedal was going to the floor and you could pump it up to regain some clutch travel, so I replaced master and slave with no results. Eventually it stayed on the floor, I found the clutch arm that the cable normally pulls to disengage the clutch is at the end of its throw butted up against the case of the transmission. I inspected the fork and arm and nothing appears to be bent or broken at all. Replaced the pressure plate and the same result, the arm moves through 95% of its throw before the throw out bearing contacts the pressure plate. Any ideas what I should be looking for here?
clarkekent13
Transmission & Drivetrain
Feb 7, 2010 04:27 PM
Wazup
Oct 6, 2008 08:37 PM
triniSiR
Jul 31, 2008 08:44 AM
jb0705
May 15, 2007 05:39 PM
92 CIVIC HATCH VX
Nov 6, 2005 03:42 PM
