Transmission & Drivetrain Gearboxes, Differentials, Clutches
Abs rings -where to get
Old Nov 5, 2019 | 05:55 PM
southender's Avatar
Default Abs rings -where to get
I have to replace a Honda CR-V 2006 front cv half axle. Honda sells them for $650. Way too much. My vehicle has ABS. All axles from elsewhere come without the abs ring. Does anyone know where I can get the rings from. Honda does not sell them. Btw the rings are also called abs reluctor rings. Thanks, Tim
Old Nov 5, 2019 | 06:05 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Abs rings -where to get
Knock it off your axle and install it on the replacement axle. Done.
Old Nov 5, 2019 | 06:22 PM
southender's Avatar
Thanks for the idea. I had considered doing this, but figured it would be difficult to do without damaging it. Any tips on how to do it successfully would be appreciated.
Old Nov 5, 2019 | 09:15 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Slow, gentle taps with a hammer and a flat blade screwdriver rotating the axle after each strike to remove the ABS ring in a flat manner. Too much movement in one area will cause an inconsistent angle and potentially crack the ABS ring. Then it is game over.
EG civic
Nov 11, 2020 11:44 PM
czissman
Oct 22, 2009 05:33 PM
94_teggy_rs
Jan 28, 2008 08:36 PM
