2000 DX Sedan manual transmission rebuild kit
Old Nov 5, 2019 | 11:06 AM
WendyArmbuster's Avatar
Default 2000 DX Sedan manual transmission rebuild kit
Greetings! My manual transmission is making a whine when I'm applying throttle, and it goes away when I push the clutch in while parked. I'm planning on replacing all of the bearings in the main and countershaft, and I was considering a set of bearings and seals from RockAuto, with the part number ZMBK386. The description on their page says it's for an HX, but I have a DX. Will it work? They don't show any other options for a DX. Thanks!
Old Nov 5, 2019 | 11:16 AM
BiggieBert's Avatar
Loved
Community Favorite
Default Re: 2000 DX Sedan manual transmission rebuild kit
You can compare part numbers at a honda parts site such as hondapartsnow.com or check out syncrotech’s site for their rebuild kits. Sorry I don’t know the answer to your question.
Old Nov 6, 2019 | 12:40 PM
DaX's Avatar
DaX
Loved
Community Favorite
https://shop.synchrotech-transmissio...d-Kits_c17.htm
Spend the money and buy a quality rebuild kit. Bearings and seals is $175 from the link above (scroll down near the bottom) - you just need to determine if you have 35mm or 40mm diff bearings. Give Synchrotech a call - they can help you pick the right kit.
Old Nov 8, 2019 | 01:30 PM
Thanks for the link!
sharmon
Jun 13, 2018 08:05 PM
ENK11
Aug 9, 2014 09:32 PM
syntheticblend
Mar 21, 2006 10:26 PM
