Any Tips on how to remove the 32mm end axle nut while car is....
Old Nov 4, 2019 | 05:17 PM
notnilc20's Avatar
Default Any Tips on how to remove the 32mm end axle nut while car is....
Tips on removing the nut when car is already off the ground and the brakes are gone already? It's at the junk yard so they have the cars up on stands already. I tried putting the trans in Park but it still spun freely. thanks.
Old Nov 4, 2019 | 05:35 PM
muellersfan's Avatar
Default Re: Any Tips on how to remove the 32mm end axle nut while car is....
Old Nov 4, 2019 | 06:03 PM
notnilc20's Avatar
Originally Posted by muellersfan
Ok...other than the obvious, any other tips? i might try a wrench on one of the lug nuts while I torque it off?? Just wanted to know if there were any tricks or ideas ....thanks. I cant afford a cordless impact right now....I have an air one. wonder if I could sneak in my lil compressor into the junk yard. They say no power tools though, so Idk.
Old Nov 4, 2019 | 06:49 PM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
Take a rotor off of another civic, put it on the hub, lock it down with lug nuts, stuck a bar in the vein, rotate it til it hits the frame, start hulking on the axle nut.
Old Nov 5, 2019 | 02:53 AM
NVturbo's Avatar
O.G. triple O.G.
The Mid-torque Milwaukee will remove it as well.
Old Nov 5, 2019 | 04:44 AM
tony_2018's Avatar
Fish Twig
Makita 1/2 inch too....
Old Nov 5, 2019 | 05:58 AM
Blue-Civic-Hybrid's Avatar
Loved
My Dewalt did the job just fine also, just buy a decent impact gun.
Old Nov 5, 2019 | 06:36 AM
ERA_Evil's Avatar
Picture for reference, you can try to put some solid metal or re-bar in this fashion to lock the hub, and then simply get your ratchet and socket and proceed to take it off. If you are unable to do so or do not have the strength, simple get a long metal tube and out it on the ratchet handle. Basic physics principle, by extending the handle, the farther away you are the less "strength" you need to be able to remove it.
Bare with me on the pic, I know its not correctly drawn (that would be to "tighten"), but simply lock the hub against the car itself. Hope this can help you out
Old Nov 5, 2019 | 04:28 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
The OP said he doesn't have the budget for an electric impact gun... so the low budget answer is to put whatever is necessary to get the front corner lowered on to the ground (front rotor and a wheel/tire with at least two lug nuts), and once there, you can use a 32mm socket with a 1/2" pry bar and use a long piece of pipe slipped over the pry bar to increase your leverage power.
Old Nov 5, 2019 | 04:36 PM
BlackJack_DC2's Avatar
i say do this and use a jack to crack it loose
Last edited by BlackJack_DC2; Nov 5, 2019 at 04:40 PM. Reason: JRCivic helped explain what i was trying to say
Old Nov 5, 2019 | 06:43 PM
collinkuhn1's Avatar
His problem isn’t that he can’t break the nut, it’s that the car is in the air so the hub just spins when he cranks on it. What I have done before is jammed a piece of rebar in the wheel studs and spun it until it gets jammed against the body of the car to hold the hub in place
Old Nov 5, 2019 | 07:26 PM
Chrisfrom1986's Avatar
His problem is he isn't using the resources available to him already at the junkyard. Caoboy already explained how to do it.
Old Nov 5, 2019 | 07:40 PM
notnilc20's Avatar
Hey guys, thanks for all the help. I went back there today and I did go with what caoboy had said. I have a large flat head screwdriver and I stuck it into the vents on the edge of the brake rotor.....then I got a wheel that was laying nearby because my screwdriver wasnt long enough to catch a good place on the wheel well or make contact with the ground....so I just used a spare wheel and layed it so the screwdriver would contact the wheel as I loosened the axle nut with my breaker bar and 32mm socket. Hope that makes sense. Thanks again.
Old Nov 5, 2019 | 07:48 PM
Caoboy's Avatar
-Intl Steve Krew
Loved
Awesome!
Old Nov 6, 2019 | 05:45 AM
tony_2018's Avatar
Fish Twig
Not a bad idea, less weight to carry although I bring my 3/8 impact with me most of the time just to hit out some 10mm before I leave.
PoorDad
12
Aug 13, 2019 11:39 AM
MitchHamilton
Dec 7, 2016 01:31 PM
MadVladCivic
May 5, 2015 03:56 PM
B18EG6
Apr 16, 2006 03:51 PM
LsHoney84
Feb 4, 2005 08:31 PM
