Need help on 1992 Honda Civic Si Hatchback motor mounts!!
Okay I have a 92 eh3 and it currently have solid motor mounts on them and I would like to replace those. I bought oem spec motor mounts but they have a 2 bolt pattern and the mounts currently on them are 3 bolts... it has a d16z6 motor and a s20 transmission... here are some pics...
Re: Need help on 1992 Honda Civic Si Hatchback motor mounts!!
The OEM 3 bolt mount for this chassis is for the Si D16Z6 motor. If you get the OEM 92-95 Si motor mount it should be the 3 bolt pattern.
The other option is to goto the junk yard and pull the bracket that is bolted to the block and swap yours out. I think it would require removing the timing belt if I remember correctly.
