01 crv b20b swap no fuel no spark.
Okay so recently I swapped my high mileage motor out in my crv that ran with a b20b swap with low mile . The car cranks but wont star . The fuel pump is not priming when key is turned over and I'm not getting any spark. I have a jumper harness for an 8pin to 10pin on my distributor and I did the ckf bypass for the no crankshaft sensor. The grounds are all good and the ground on the thermostat housing is good and tight. The ecu and fuel pump fuses are also good. I'm stumped. Any help would be great as the car ran before the swap and had fuel and spark.
project92ex
Oct 25, 2008 11:00 PM
PrestonCRX
12
May 12, 2006 02:00 PM
