97 honda civic revs to 3k and wont go down!!
Old Nov 1, 2019 | 03:47 PM
Jordan Wilson's Avatar
Default 97 honda civic revs to 3k and wont go down!!
So I swapped in a B18B. I am in the process of turbocharging it. It was running fine, then one day I went to start it and it revs to 3k and holds. Dosen't move, just pins 3k and holds. Any ideas?
Old Nov 2, 2019 | 04:11 PM
Default Re: 97 honda civic revs to 3k and wont go down!!
Any ideas would be appreciated!
Old Nov 2, 2019 | 06:26 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Search "Hunting Idle" and you will get instructions to troubleshoot this...
Old Nov 4, 2019 | 12:17 PM
Chris Neven's Avatar
Intake manifold hose came loose? Any air hose loose? That was my problem after a head gasket swap
Old Nov 4, 2019 | 02:04 PM
Spaceturtle917's Avatar
Cover up your iacv port on the throttle body and see if that fixes it. If not spray carb cleaner on the troubled areas such as hoses and gaskets on the intake, fuel injectors as well. If the idle drops where you spray it you found your vacuum leak.
OjJuiceMan
Apr 20, 2011 11:15 AM
vteckyle
Oct 23, 2007 06:49 PM
b18cEK
Jul 13, 2006 06:09 PM
racer_X_123
Oct 25, 2005 01:43 PM
