B20v i found golden flakes in vtec solenoid
Old Oct 26, 2019 | 03:16 PM
CSmokey's Avatar
Default B20v i found golden flakes in vtec solenoid
What Could it be I was told it was probably bottom end problems but I’m unsure
Old Oct 26, 2019 | 05:30 PM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
Default Re: B20v i found golden flakes in vtec solenoid
Check your oil and see if there are metallic flakes in it...
Old Oct 27, 2019 | 05:59 AM
chrysler kid's Avatar
Its means you're rich. Beverly Hill billies rich. Gold is very valuable
Old Nov 9, 2019 | 01:12 PM
CSmokey's Avatar
i dropped the pan and I can’t find any shaving there
Old Nov 9, 2019 | 01:57 PM
CSmokey's Avatar
Help anyone
Old Nov 9, 2019 | 02:23 PM
Caoboy's Avatar
-Intl Steve Krew
Loved
Did you clean the solenoid and put it back on?
​​​​​​If you don't have metal shavings in the pan, and you don't have low oil pressure, and you don't have recurring shavings in the solenoid, there is nothing to worry about.
Old Nov 10, 2019 | 07:29 PM
They probably used copper gasket spray on the head gasket and youre seeing the remnants of that in your oil. Change the oil and filter and check again
Old Nov 10, 2019 | 09:56 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
OP, you are panicking and running down rabbit holes without logic. Clean out the VTEC screen and re-install it. Drive it a few miles. Re-check the screen. If no more flakes show up, it is likely that what you have discovered is merely something that appeared from a failure to fully clean everything during the rebuild. Another possibility is that this VTEC assembly was from another engine and was simply installed on your engine without cleaning.
You have found no evidence of gold/copper colored flakes anywhere else in the engine. You know that this type of material only comes from the main and rod bearings... and this would be found in the pan as well. If the engine runs well otherwise, stop borrowing trouble and enjoy it.
Old Nov 11, 2019 | 12:19 PM
CSmokey's Avatar
the shavings are coming from this hole
Old Nov 14, 2019 | 12:20 PM
CSmokey's Avatar
Old Nov 24, 2019 | 11:45 AM
CSmokey's Avatar
Anyone know
Old Nov 24, 2019 | 09:15 PM
JRCivic1's Avatar
10 Year Member
Community Builder
It looks like shavings from threading the plug on the bottom of the head preparing the head for CRVtec use. Until this is all cleared out, you may see more of these fragments/shavings. The good news is that the VTEC screen will catch them all and the likelihood of any pieces getting past and causing damage is extremely slim.
Old Nov 25, 2019 | 06:18 AM
The shavings are from that valve cover. If you take the oil cap off I think you will see the paint is falling into the oiling system from that yellow valve cover
Old Nov 27, 2019 | 05:29 AM
tony_2018's Avatar
Fish Twig
I noticed the bits and pieces by the solenoid as well.
1998GsRIntegra
10
May 1, 2011 05:05 PM
d16vteceg
Jul 8, 2006 09:36 PM
da9driver
24
Aug 25, 2005 01:00 PM
H22A_HB
Oct 22, 2004 11:10 PM
FlipboiGSR
Oct 8, 2001 04:51 PM
