Heating problem Civic 2003 1.4 Hatchback
Old Oct 25, 2019 | 11:33 AM
OndraBor's Avatar
Default Heating problem Civic 2003 1.4 Hatchback
Hello, I am new to this forum , please bear with me.
I have a problem with heating in my car. I eventualy found out that the air temperature blend door is really sticky and hard to turn (I mean the one that works with mixing hot/cold air, not HCV). The cable that runs from center dash was bent due to the hardness of turning, so I removed the whole center console. I found out that the cable runs to the bottom of drivers dash where it connects to some plastic gears. When I tried to move it by hand it was really hard, near impossible to turn. But eventually I heard that switiching noise. So it works, its just really sticky. Does anyone know how to fix this please? There is a really bad clearance to the gears, potentionally blend door.
Here is a link to what I exactly mean. 8:10 - 9:00
My video -
Thanks for any help!
Old Oct 30, 2019 | 08:20 AM
aw614's Avatar
10 Year Member
Loved
Default Re: Heating problem Civic 2003 1.4 Hatchback
I think you have to replace them, I am currently going through with the same thing on an 04 civic lx as it would get stuck on full heat. The door for the cold/heat and defrost are all giving me issues. I got it turned enough to get cold air back since Im in florida and heat isn't as much of an issue...
Have you tried checking to ac codes? I believe code 9 is the blend door when the diagnostic is run.
Old Jan 5, 2020 | 10:15 PM
Paxton James's Avatar
I'm having the exact same issues, I cannot generate heat. I did the self diagnostic and came up with 9 flashes which is the blend door/motor. Tonite I pulled and tested the motor which works perfectly. My fears and water shutoff valve or very hard to activate by hand, so I believe I need an entire heating box, unless the blend door is serviceable. 😪
Destiny Hooks
Jul 11, 2018 01:09 PM
alphamatt
Honda Civic (2006 - 2015)
Jan 7, 2013 02:06 PM
RexWu
Honda Civic (2001 - 2005)
Sep 25, 2011 01:40 PM
lude1888
Sep 20, 2006 02:36 PM
Agent STFU
Jul 23, 2003 06:38 PM
