Bypass crank fluctuation sensor??
Old Oct 24, 2019 | 04:45 PM
Justin. J's Avatar
Default Bypass crank fluctuation sensor??
Is it possibly to bypass a crank fluctuation sensor on OBD1 engine harness (1995 integra) ’ve put in a B18c1 which is OBD2 (out of 99 integra) Every wire is plug and play except the CFS. And there is no connector from the 99 that is the same as the one in the 95
Old Oct 24, 2019 | 05:02 PM
Chrisfrom1986's Avatar
Default Re: Bypass crank fluctuation sensor??
There is no ckf sensor on a 95 Integra.
Old Oct 24, 2019 | 07:31 PM
jdmark1's Avatar
So just don't plug it in? Or am I missing something?
Old Oct 25, 2019 | 08:25 AM
NVturbo's Avatar
O.G. triple O.G.
OBD1 engines don't have the sensor (located behind the crank pulley). The sensor is inside the distributor.
Old Oct 25, 2019 | 06:32 PM
No, obd1 engines don't have a ckf sensor period. The sensor inside their distributor is the cyp sensor.
Old Oct 26, 2019 | 05:57 PM
wunfstgsr's Avatar
Loved
Community Favorite
So you have a obd2 swap with the OBD1 engine harness. The obd2 swap does have the CFK sensor. Now are you using a OBD2 ECU? and is it throwing the code? a OBD1 ECU should not throw this code. If you do have a OBD2 ECU you must bypass the sensor or use a OBD2 harness to plug into the sensor. read this,
OBD2 Civic/Integra CKF Bypass Trick ? .:FFS TechNet:.
akinas-crx
Oct 28, 2011 06:00 PM
jjmcmana
Nov 1, 2008 09:02 AM
teddy_dc2
Oct 4, 2007 07:54 PM
FOMULA91
Nov 17, 2005 10:33 PM
EKB18BPR3
Mar 13, 2005 07:22 PM
